AnEv942
Feb 06, 2019Nomad
Yes, I shortened our 28" to 22 1/2". I cut the ball mount end. After removing the reinforcing ring and chain plate (grind thru welds) cut tubes 5 1/2" and re-welded the ring and plate. Only need to redrill the pin hole. Then cut a few links from chains.
Ours is older 2" truss-
