- TxGearheadExplorer IIBigfoot wants a 4X4 across the front, right at the skirt, and at the rear.
- stevenalNomad II
Happijac wrote:
https://www.happijac.com/images/pdfs/4150and45-4600.pdf
For added safety and stability, support the camper floor with blocks and use camper jacks to stabilize.
I have always followed this advice. I have noticed that dealers never do. - notsobigjoeNomad IIIHere's a great idea OP and inexpensive as well as not really being a whole lot of work.
https://www.truckcampermagazine.com/camper-mods/contests/off-the-truck-camper-support-system/
Also I'd like to add that I don't think there is a correct or incorrect way of doing this. What ever your comfortable with. - JRscoobyExplorer II
Grit dog wrote:
JRscooby wrote:
Anybody remember the plywood Xs we used under water beds? Cut 1 sheet of 3/4 into 2 X 4 pieces, then notch in center of each. Another sheet on top, and maybe 3rd on the on the floor, would hold up couple feet above floor. If setting on pavement or even leveled gravel, the sheet on bottom would not need to by as thick, just hold the edge of other sheets out of water.
And for somebody that wanted to unload and use camper in a site, could double the sheet on ground. Could be carried under camper, raise it 3 inches.
3 sheets of 3/4 ply to gain 1-1/2" over the plywood X method? Lol
PS 3/4" x 3 = 2-1/4", not 3"
But on a practical note, when I first bought a TC, I thought that was a nifty idea. (The X, not the extra 130lbs of 2 more sheets of plywood on top of that)
And then I quickly found out that I just cut up a good sheet of plywood and made it useless. As the X ONLY works if the ground it's unloaded on is level, firm and flat.
3 sheets. 1)cut to form X. 2)Laying on top. 3)Lay on floor But the 1 on floor does not need to be thick. Or even used at all. If unloading on ground, or gravel, need to spread the load. In fact, doubled, the camper weight could be supported on pretty soft dirt. (BTW, I think that brings the total sheet count to 4)
Now, if a double stack of pallets, with less surface area, will hold it up, how do you level that? Plank on blocks? I think that would be about 4.5 square feet, instead of 32 square feet. - BurbManExplorer III
mkirsch wrote:
BurbMan wrote:
JimK-NY wrote:
I have never heard of a jack failing or any major issue....
Then you haven't read this thread.
Not a fair comparison by any stretch. That camper was not designed for corner jacks, they were not properly mounted, the camper was old and the wood not in the best shape, and the ground was uneven and soft.
An AF1150 comes from the factory with four corner jacks, and they don't want warranty claims, so they will make sure the jacks are well mounted.
Now if it lets you sleep better at night, put some support under the camper.
1. OP has a 10 year old camper, don't know what condition the frame is in and if there is rot by the jack mounts.
2. OP doesn't state what condition the ground is in, even though it's parked under cover there may be soft spots due to drainage, etc.
3. OP's camper is WELL outside the warranty period.
We are not talking apples and oranges here, but more like oranges and tangerines...granted the post I cited is not exactly the same circumstances as the OP here, but there are enough similarities to make it relevant. - mkirschNomad II
Now if it lets you sleep better at night, put some support under the camper. - Grit_dogTrailblazer
And then I quickly found out that I just cut up a good sheet of plywood and made it useless. As the X ONLY works if the ground it's unloaded on is level, firm and flat. - joerg68Nomad IIII am in favor of additional support when the camper is off the truck for some time. It is not much effort, and it will not hurt.
When the camper is outside, the wind can cause a little sway that may "wear" the jack mounts over time. If the camper has additional support, this can no longer happen.
When the camper is completely sheltered from the elements, it probably doesn't matter much. - JRscoobyExplorer IIAnybody remember the plywood Xs we used under water beds? Cut 1 sheet of 3/4 into 2 X 4 pieces, then notch in center of each. Another sheet on top, and maybe 3rd on the on the floor, would hold up couple feet above floor. If setting on pavement or even leveled gravel, the sheet on bottom would not need to by as thick, just hold the edge of other sheets out of water.
And for somebody that wanted to unload and use camper in a site, could double the sheet on ground. Could be carried under camper, raise it 3 inches. - JimK-NYExplorer II
I read it. It is about a failure to properly rebuild an old camper.
44,066 PostsLatest Activity: Oct 04, 2013
