jimh406
Apr 26, 2022Explorer III
My TC has been unsupported almost all of the time it's off the truck for the past 16 years. However, I did support it on my property while we were having some remodeling done. It was easy enough to do it. I used jacks like these with a board on top. for each end. It did help the stability.
https://smile.amazon.com/gp/product/B000760FWU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
I think the more likely problem is the jacks sinking if not on asphalt or concrete. Do make sure you put something under the jacks to increase the surface area of the feet. I usually use 1 ft squares of a stall mat although plywood would work as well.
