Dr__Blake
Sep 26, 2016Explorer
2DHoop - I have an AF and my frame looks exactly like yours at the front where you have the red arrow. Further, I have the same zip ties holding the wires and propane hose to solid pipe connection. Word of caution, Northwood wound the flexible propane connection to fixed connection to tight with an "open C clamp" which ended up breaking that connection. I backed off the tension on the C clamp (2 bolts) and put a small section of rubber between it and the fixed pipe to stop any rubbing. This allows a bit of movement as the trailer flexes while going down the road.
Hope you are enjoying the trailer!!
