myredracer
Sep 26, 2016Explorer II
Some of the welding done by the frame manufacturer (no names mentioned) is poorly done and even incomplete in some cases.
Having had a serious frame problem on a previous TT that was found the day after we owned it, I would recommend taking it to a reputable frame and axle shop that has experience with TTs. The one we used is a gov't certified inspection facility and they did a very detailed inspection and found a number of things wrong, including bad factory welding. They will be able to recommend any repairs if needed or if it can be leave it alone.
The points where an A-frame connects to the main frame (I-beams) is a high stress area. The frame on our TT which has 2 x 4400 lb axles, doesn't have any tubing between the A-frame members. But your frame must have a bottom mount coupler and I don't know if the A-frame connections are done differently. The cross-piece with the crack at the end looks to be the front of the floor of the TT. It may provide mostly floor support but then it might also be a very important structural connection point too. Considering the potential worst case scenario, I'd get a professional to look at it.
