dodge_guy
Jun 24, 2017Explorer II
GeoBoy wrote:dodge guy wrote:
I always say to add 1500lbs to a trailers dry weight. this will get you close to its loaded ready to travel weight. that would put a 5800lb trailer at a loaded weight of 7300lbs with 12.5% tongue weight of approx. 960lbs (you will need to load the trailer properly to arrive at this number).
As far as towing at 55-60, that will not be practical. you will get run off the highway at those speeds. I`ve run at 70 on occasion and it still isn't fast enough for most people. the 6.0 can handle it. I would think you will be OK. if your willing to get a new Tow Vehicle then why not tow with it to see how it does. then you can decide if you want something different. and with as many people that will be in the trailer you do not want to go smaller!
Are you serious? Most trailer tires are rated at a maximum of 65 mph, I have been rv'ing since 2006, with TC's and TT's and 60 mph is my max speed. There are lanes for guys like you, they are called passing lanes!
My towing speed 90% of the time is 67mph! My ST tires are rated at 86mph. I have run at 73 before but that's not often. My X tows great at 67 and I'm comfortable at that speed. Especially going through the plains, 60 mph is like eternity going through a vast expanse of nothing!
