F350mule
Jun 29, 2015Explorer
Rebuild it yourself, not that difficult. The BIG problem with these older Lances is how they put the windows in. No sealer whatsoever just foam tape under the flanges and caulk around the edges. Remove the windows and edge moulding and use a wide blade screwdriver to pop the staples from the siding. From there you can see and replace the damaged wood it's stapled together as well. And yes I've done this to two that I've owned.
You really are better off doing this yourself, dealers will want your firstborn as well,lol. You won't get much for trade in or if you try and sell it so it's much better if you do it yourself and get a few more years out of it
44,025 PostsLatest Activity: Feb 18, 2025
