Colberjs
Apr 17, 2016Explorer
smkettner wrote:
Cable, hydraulic, rack & pinion?
Otherwise yes I believe the slide should run fine on battery alone.
Not sure what it's called but it has an electric motor that turns 2 gears connected by a long square rod and the slide has a track on either end that the gears grab on to and push/pull the slide in/out.
44,056 PostsLatest Activity: Nov 19, 2013
