Old-Biscuit wrote:
Setting on 10 is too high in my opinion----brakes are still too loose.
Spin wheel and it should rotate 3/4 turn then stop when brakes are adjusted.
Agreed. I set to 10 in hopes of dialing it back to 7 or so to keep them from locking up. I you-tubed adjusting brakes and one video said to turn the star wheel until you can't manually turn the wheel by hand and then back off the star wheel about 8 times. Does this sound right. I assume you are also suggesting that once brakes are adjusted properly they should only rotate 3/4 turn without applying brakes while tire/wheel are still in the air. I know for a fact we could turn ours and it would spin a few rotations or more. tks
