Passme wrote:
Am I to understand that after the break in period with our new trailer I should be able to spin a tire and it will rotate 3/4 turn then stop when my brakes are properly adjusted. Is this star wheel adjustable without removing the wheel, ie accessible from back side of hub? Thanks, this is all new to me.
If it was towed a good distance to the dealer they should already be broken in (burnished the magnets and seasoned the shoes and drums). And no you want a slight drag. If it stops in less than 2 revolutions it's too tight. And with electric drum brakes you will always hear the magnet contacting the drum occasionally. Adjust them so that if you give it a good spin it spins at least twice!
