valhalla360
May 31, 2020Navigator
Crespro wrote:
I appreciate the caution and have researched this quite a bit. It is rated for 19.2K on towing a 5th wheel, has 26K GCWR, 3.6K payload and scored 94.5 points on the IKE. It meets the weight specs. The Ford engineers are right on this truck.
At 16.8k loaded, assuming 20% hitch weight (lower end of recommended percentages), that's 3360lb hitch weight. Add in a 200lb hitch and you used your full 3600lb payload before putting anything else in the truck.
People, firewood, gas jugs, running boards, etc...all count against your payload.
If it's nearer to the upper end of 25% you will be way over with an empty truck.
Not saying it will be a death trap but if you can change the order, why not fix the issue now when it's simple and cheap.
