The largest offenders I found of water getting out in my camper where not the shower curtain. It wraps around enough that unless you spray the water at the ends it's not the issue. I just smooth mine along the walls and make sure it is wrapped all the way around.
For me, I found that I had two places water would end up on the floor:
One was the shower hose itself, which was stiff and ran up to the shower head at an angle giving the water a path down behind the curtain and onto the floor. A longer, more flexible hose (Inox)that would run from the faucet, under the shower curtain and up to the shower head took care of that issue.
Issue two occurred if the trailer wasn't perfectly level side-to-side. Water would run down the shower walls and along the gap between the tub and wall panels and then down onto the floor. A small "dam" made from tub and tile caulk in the gap makes sure that it gets directed back into the tub before it can run onto the floor.
