GrodymanExplorerMay 01, 2016Shower LeakSo I have a leak at the shower drain, I think the p trap threading cracked. I think the factory didn't size everything properly and there is stress on the threaded p trap connection. Would it be wi...Show More
BB_TXNomadMay 01, 2016Mine started leaking last year and it was simply a loose fitting nut. Tightened it and no more leak. If yours is standard size plumbing pipes and P trap you could probably replace it yourself if it is cracked.
Related ContentNautilus P1 has leaking connectionsShower leak?Leak under showerQuick connect exterior shower hose doesn't connect.Oxygenics Fury RV Handheld Shower head --COLD drip
