gserveExplorerMay 03, 2015Silicone greaseWhat do you use on the "o" ring on the water filter housing? The manufacturer says to use silicone grease. What kind do you use?
15 RepliesReplies sorted by NewestShow MoreBTPO1ExplorerMay 03, 2015Shadow Catcher wrote:Look for food grade O ring lube i.e. Amazon linkX2, ensure food grade.Shadow_CatcherExplorerMay 03, 2015Look for food grade O ring lube i.e. Amazon linksremsingExplorerMay 03, 2015I know some folks use a small amount of vaseline.gserveExplorerMay 03, 2015The plumbers grease I've seen say not for use on synthetic or rubber " o" ringsnewman_fulltimeExplorer IIMay 03, 2015plumbers grease
Related ContentGrease vs siliconeAnything other than silicone..Grease gun/ grease recommendationsSilicon grease on dump hose connections?Maintenance for Silicone Roof Coating on EDPM
