RCMAN46
Feb 08, 2016Explorer
Perrysburg Dodgeboy wrote:GeoBoy wrote:
You should use a synthetic lube like Amsoil Torque Drive and over fill the transfer case by 1 quart. To overfill remove the switch in the top of the case and add the lube there.
Why would you ever overfill any component? This will cause seal failure any could cause the component to fail also. Not a good idea at all!!!
Don
It will also cause more friction and churning up the oil and may lower the lubrication ability of the fluid.
Overfill your engine by 50% and find out what will happen.
