wwest
Jul 05, 2014Explorer
Traildust wrote:
The PD9260 Converter and the TM500A Battery Monitor in our Arctic Fox have always agreed when it comes to charge voltage at the batteries. I have installed a Charge Wizard Pendant to the Converter so I can manually select Boost Mode and it's worked out just fine. Now when I select Boost Mode I see 14.4vdc at the converter but only 13.7vdc on the TM500 and at the Batteries? This is after 12 hours and batteries were discharged to 12.3vdc when I began to recharge them, they never went over 13.7 even though Converter was showing 14.4, am I missing something here!
Thanks for any help,
Bill
At the converter which 12 volt source are you measuring, the 12 volt "house" load source or the battery (re-)charging source?
