falconbrother's avatar
falconbrother
Explorer II
Jan 31, 2017
Single Axle travel trailers.
Wanting your opinions on single axle travel trailers. Background:
Our first TT was a 16 foot Prowler, single axle. That single axle caused more than a few white knuckle moments for me, or at least I believe that it was the single axle. That is, in a gusting cross wind, passing semi-truck, etc.. it would sway, bad. I had always been told that double axle TTs wouldn't sway as bad.
Now I see a lot of 19 or 22 foot long single axle TTs, mostly the Wildwood brand. Other than the single axle they look pretty good (I'm not considering one because I want a slide out). If that 16 footer got wild I can only imagine how a 22 footer would be.
If you have pulled a single axle 19 - 22 foot long TT what was your experience?
I will say that other than towing we loved that little prowler and had some amazing trips in that camper..
  • Agree. I have pulled all kinds of trailers and the number of axles was not the determining factor in how well they towed. Percentage of tongue weight might be a little more critical but you want any trailer to be set up properly.
    Of course one is limited by the tires and suspension to a lighter load than a tandem axle with everything else being equal.
  • Totally agree !!! We have pulled both single and double axle trailers. Never had a problem. What are you pulling your trailer with? Maybe your vehicle is under-sized, even for 16 ft trailer. If you have the right setup, you wouldn't even know a trailer that small is behind you !!!
