- rhagfoExplorer III
blt2ski wrote:
Lantley wrote:
blt2ski wrote:
Assuming both the single and the dual axeled rig have the same GAWR, assume 10,000 lbs,same overall width of 8'
,the single axel will weigh upwards of 200 lbs less than the dual rig. a semi with a 20K axle will be 300-400 lbs less with super singles. As such, singles will have more payload potential than a dually. Being as they weigh less, less HP/torque is needed to get the tires moving, along with staying moving at a given speed, so better MPG should be expected and achieved. Assuming these specs, the single tired rig is the better option.....
Marty
1st paragraph scenario DRW truck will still have better braking and more stability. The axle rating is not the determining factor when it comes to comparing towing performance between the 2 trucks.
Physics (wider stance) still plays a factor.
I stated overall width would be the same! BOTH would have the same brakes, as they are both rated the same. Having diven rigs with the same dual vs single axel with the same everything, reality, no difference in handling, and the extra payload is there for the single rig, as the tires and rims weigh overall less on a single, than a dual rig.
In the video, obviously the rig that is shorter and narrower will win the driving thru a car wash, drive thru window etc. Shorter in height is also a big factor getting thru some drive thrus too.
Again, assuming the only difference between two rigs, is a single vs dual tires, the single is the better option. Hence why one is seeing many more tractor trailer rigs with singles vs dual setups. tare wieght savings, better traction, better braking, better mpgs etc. If we pickup owners could get the same wide width stance with a single as a dual, then yes, the dually is better in some standpoints.
Marty
Marty, you are comparing apples to oranges. You are basing your statements on commercial regulations. Modern pickup have rear axles rated below what the axle manufacture rates them, but that is only for the axles carring capacity, it doesn't include the braking capacity. If one puts 19.5" wheels and tires on a pickup, you can easily exceed the trucks manufactures axle rating. That rating is based on the least of spring, brake, frame, and tire. If you put 19.5" tires, you solve that issue, but what engineering degree do you have that qualifies to say the tires were the only item not within the axle manufactures axle rating. - SRW for me. I would prefer to compromise with a smaller trailer than the wide truck. Now if there was a special model with a narrow axle to fit the dual without the flares that would be my ticket.
- Cummins12V98Explorer IIIHuntindog, thumbs up!
- blt2skiModerator
Marty
Marty - LantleyNomad
blt2ski wrote:
Assuming both the single and the dual axeled rig have the same GAWR, assume 10,000 lbs, same overall width of 8',the single axel will weigh upwards of 200 lbs less than the dual rig. a semi with a 20K axle will be 300-400 lbs less with super singles. As such, singles will have more payload potential than a dually. Being as they weigh less, less HP/torque is needed to get the tires moving, along with staying moving at a given speed, so better MPG should be expected and achieved. Assuming these specs, the single tired rig is the better option.....
Now if you want to compare the 2500 I have with a 6000 gvw RA, to my 05 dually with an 8500 lbs capacity, or the 16500 RA in my International dump truck.....Pretty easy to tell which rig will win the most potential payload, best ability to tow a larger trailer etc.
So, at the end of the day, how would you like to compare the two?!?!? 1st paragraph? or 2nd paragraph?
Marty
Physics (wider stance) still plays a factor. - blt2skiModeratorAssuming both the single and the dual axeled rig have the same GAWR, assume 10,000 lbs, same overall width of 8',the single axel will weigh upwards of 200 lbs less than the dual rig. a semi with a 20K axle will be 300-400 lbs less with super singles. As such, singles will have more payload potential than a dually. Being as they weigh less, less HP/torque is needed to get the tires moving, along with staying moving at a given speed, so better MPG should be expected and achieved. Assuming these specs, the single tired rig is the better option.....
Marty - HuntindogExplorerPeople have to make compromising choices in most all aspects of life.
TVs are no different.
Some need to use their TV as a commuter vehicle.
Drive thrus and parking garages and Duallys do not play nice together.
So those people are best served with a srw.
What I do not understand is the srw crowd that insist that their truck tows just as well as a dually.
That just isn't so.
I know you all love your trucks, but that doesn't make it so.
There is a reason that dually owners put up with the inconveinences of owning one.
It is less of a compromise between commuting type service and towing type service.
Duallys just flat out tow better than srws.
To the srw crowd that believe otherwise... You compromised. And it's OK to do so.
There are help groups availible for those that are having trouble with facing reality.
It can be overcome with time.:B - Grit_dogNavigator IIILived up to your name....."Fish on!"
I predict 8 pages by tomorrow! Especially with theories like "duallies have less capacity because the wheels weigh more..." ROFLMAO - 1320FastbackExplorerFor me Single is the best
- blt2skiModeratorDepends on truck type style. If you can go singles, carry the same weight in a given axle as duals, singles will carry more payload. Generally speaking, have better mph, stopping etc.
If given a choice, I'll take singles. One does not always have a single tire with upwards of 10,500 lbs per tire that is needed to carry a legal 20,000 per axle.
Marty
44,056 PostsLatest Activity: May 04, 2014
