I encountered a nasty drop off while exiting a gas station and bent my skid plate angles almost to the black and gray pipes in a bone chilling scrape.:E Does anyone know where to get a set of rolle...
I did this on my first TT. It was really old and had a very stout frame. It worked well, but once i raised it for better ground clearance the problem was solved. With todays engineered frames, many don't have any extra strength for using the wheels. I would look to raising the TT as the solution. If you believe in the theory of stabilizer jacks being able to twist the frame when over tightened/unqual tightened (I do) then wheels are really bad for the frame... I would urge extreme caution.
