49ford wrote:
I haven't found a connection to motor where I could put 12 V to it. I'll take some panels off and see if I can spot one.
ON the furnace, I've had the gas on for a day now and ran the other 3 things. I'd have thought it would have bled air out. I'll try it a couple more times. Can you "hear" the ignition snapping if its trying to light?
I also found out you have to turn the tanks on slowly, or they shut down
Does your stove work?
Having the tanks shut down like that might indicate a regulator problem, or propane leak.
