49ford's avatar
49ford
Slide and furnace problems
I'm a newbie Rv'r. We have a 08 Keystone Passport Ultra Lite 285. We used it a yr ago and everything except outside grill worked. We tried it a week ago and the slide won't work, the furnace won't work.
So far, on the furnace. I have two full propane tanks, the water heater works, inside and outside grill works.
On the slide, I have a good battery charged to 13.5V, I have manually moved the slide out partially so its not stuck. I pulled the switch out and it has 12.5V from blk to red wires. I checked circuit breakers in front behind battery and cleaned terminals and continuity. Good, but one had seized nut and connector, so I have two new cb's coming. I tested slide by jumping and didn't move. I have checked every fuse, flipped every breaker two or three times. I think everything else in the unit works including AC. Does anyone have any ideas?
thanks
  • On your furnace, clean it well, and prior to lighting it ignite all burners on your stove and let it run for a minute. I have found on my keystone passport that this helps to purge in air that is in the lines prior to furnace ignition. The furnace may "time out" if it doesn't get flame ignition in a certain amount of time.
    Sorry, but I have nothing to suggest on the slide out situation
