- HuntindogExplorerThere is no good solution for snow. A lot of it will render a topper useless. Might be easier to deal with snow without one.
- ScottGNomadThat's a tough one. If you don't have a cover you'll have to clear off the top of the slide before you retract it. If you do have a cover the snow will collapse it and I'm not sure what the effects of doing that repeatedly are.
Here is about 3" on mine. I have a long piece of styrofoam under each awning to support it in the rain - it sags bad. With the help of that, it took the snow ok but I didn't retract it that way. I'm not sure what would have happened if I had.
BTW, my TT came with a grade of Carefree slide out covers that is so cheaply made, only the OEM can buy it. I can't even get parts for it.
They really are a POC.
I've installed the consumer grade of Carefree awnings and they are twice the product these are.
I have no doubt I will have to replace them someday.
Pure junk. - TUCQUALAExplorerSlide cover would be a good idea not just for snow, but any debris or rain. As to snow, without cover, you'll probably need to clear top of slide to even get the slide to retract. Pushing even a couple of inches of snow on the slide top, will pack into the top seal and jam the slide flange. Ask me how I know!!! Even with a slide cover or topper, most amounts of snow will force the vinyl down on top of the slide, but usually the stuff will fall off as the cover wraps around the tube. If anything, just have a broom handy to help knock the snow off as the slide retracts, esp if wet and heavy. You won't get any inside the trailer.
I've installed 5 toppers on 3 different trailers, and very easy to do. Your slide certainly isn't 14 ft like our main slide, and it was the only one needing a second body to help with the heavy stuff. Great model is the Carefree SOKIII. You can find install pdf at Carefree website to get an idea of how to install.
44,052 PostsLatest Activity: Oct 14, 2025
