JBarca
Mar 17, 2014Nomad II
Hi aarond76,
It sounds like you found my slide floor post.
Slide Floor Water Damage (Long with lots of pics)
Slide floors, they have evolved since the Darco bottoms however they have had failures as well along the way.
Coated slice floor was the next trail after the Darco. See here, This is a thick plastic bonded to the OSB board. The issue is water separates the ends and any chip in it pending where it is, can be an issue.
The coating advanced to this
http://www.parklandplastics.com/duroslide.shtml#1
I have not tried to buy some from them, but it is a lead.
Other options, marine grade plywood if you can still find it. This will stop the rot but still need to cover it with something. If you do not have rollers the slide floor slide on, then bare wood may cause too much friction and the slide drive might not extend/retract it.
The Darco helped cut the friction.
If you still want the 12 mill Darco, see here when I got mine,
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23443150/gotomsg/23823889.cfm#23823889 General RV in Wixom. I had to talk them into gently folding it and shipping it, but they did. I even went direct to Darco who no longer seems to offer that product, they offer a different one now. If General will not ship or out of it, Jayco still uses the Darco type of membrane. Find a Jayco dealer than they can order it.
Regardless of how you do this, A drip edge is a must in my book and no exposed holes up the bottom in the membrane.
Here is the problem. No drip edge
The fix. An effective drip edge and Eternabond sealing it to the camper
To change the entire floor, did you find the U tube showing putting the 2 x 4 stilts on the outer corners to hold up the slide? If not I'll hunt for it.
Hope this helps
John
PS, if yours has a chamfer on the bottom starting end of the slide floor, make sure you add that to the new floor. It can affect the lift timing if you have the Lippert rack and pinion drive system like I do. A buddy of mine had his done and the dealer miss that chamfer. Tore up the inside of the camper hitting the wall before the slide lifted.
Hope this helps
John
44,068 PostsLatest Activity: Jun 10, 2026
