fcooper
Mar 17, 2014Explorer II
aarond76 wrote:
(text removed) I plan on replacing with 23/32 plywood. (text removed) This does not seem like rocket science, just labor intensive. Still looking for the best way to seal the bottom of the new floor once installed.
This is not your final seal solution, but you can add a lot of water resistance to your new plywood by coating it with resin/hardner for fiberglass. My buddy helped me rebuild a boat (he's been building boats for 30+ years), and he had me mix resin and hardner then paint all new plywood with it before we used the plywood for a new floor in the boat. Cut the plywood to exact size needed, and then coat all sides and edges.
Fred
44,068 PostsLatest Activity: Jun 10, 2026
