jmcgsd's avatar
jmcgsd
Slide goes out, not in.
I have a 28' TT with a slide. The mechanism appears to be a Happijack. I normally leave it with the slide extended. It's been in that position for about a month. I went to bring the slide in today and absolutely nothing happened when I moved the switch to "In". It is of course extended most of the way, however I can move the switch to the "out" position and the motor runs and the slide tries to move although it's fully extended.
That makes me think it's not a battery issue (and the battery monitor does show full charge.) I tried shorting the terminals with the same result as using the switch, so it's not a switch issue.
Any suggestions would be gratefully appreciated.
Thanks.
Joe
  • Try to manually retract it......see if it is binding.
    Then try switch 'IN'
