SteveAE
Oct 03, 2013Explorer
You may want first think about what you are going to do with your battery. If there is no power to the rig, your battery will be drained (even if you don't use it), possibly to the point of being damaged (esp. in the cold temps). So you might want to consider removing the battery, bringing it home, and storing it inside a garage with a trickle charger connected. Of course, if you do this, there won't be any power to run the slide. If your rig is new (like brand new), maybe the dealer hasn't installed a battery yet, in which case all is good....except your slide won't move.
Have a great winter,
Steve
Steve
44,059 PostsLatest Activity: Mar 18, 2026
