MFL
Dec 01, 2017Nomad II
You don't say what slide system you have, or if it has always done this/just started now? Some slides have teeth/gears that can be dry lubed. You can make the rubber wipers more slippery with 303, or baby powder. I use protect-all on my slide end walls, including the windows and frames.
Is your battery fully charged? It takes more power to retract than to extend. Even if hooked to shore power, you need a strong battery. I leave the door open when retracting, as it seems to help to not be compressing the air, when making a larger space smaller.
Jerry
Jerry
