RV17
Jul 19, 2017Explorer
Slide out adjustment advice required
So my slide out started squealing from what sounds like metal on metal. My unit is a Keystone Hideout 29BKS and while sitting in the driveway I leave it a bit tilted fwd as the driveway is slanted and also to let water run off it because I don't need it perfectly level. It also slants a bit to the slide side. Although, I can't imagine this slight weight imbalance would cause such a drastic grinding noise.
Hopefully the following video works!
https://photos.app.goo.gl/Uaf3WeaoFsPq9oTe2
