SoundGuy wrote:
Your interpretation ... anyone who gives this idea any thought at all should easily recognize that any trailer which hasn't been completely lifted off it's suspension system is inherently going to rock as people walk around inside. Obviously if you attempt to prevent this by placing supports under any slide assembly that's going to put stress on the slide assembly, stress for which it was not designed to sustain. That's common sense. :R
I doubt I’m alone in that interpretation. Just to be clear, it’s not WHAT you’re saying that’s at issue. It’s HOW it’s being said. If you’re response is making the OP feel dumb, then your delivery needs work. If you just can’t do it, then maybe you’re taking this little pass-time too seriously. Thanks for reinforcing my point.
