RoyB
Jan 18, 2014Explorer III
I will add have you replaced your battery terminals recently - maybe they are put back on reversed...
Make sure the PRINTED WORD NEG on the battery case goes to frame ground...
If they have been reversed then you should also look for an in-line fuse near the battery blown and two fuses in the 12VDC distribution Panel labeled REVERSE POLARITY. These three fuses also blow when the battery cables are reversed...
Your slide motor is usually connected direct to the battery terminals so they may placed on the wrong terminals as well...
Just something to check before moving cables on the back of the slide switch. I'm assuming the slide switch has worked correctly in the past???? Those slide switch connections just don't get reversed by themself.
Whenever we see questions like this the first thing folks ask is what have done to the RV trailer recently...
Roy Ken
Roy Ken
44,066 PostsLatest Activity: Oct 04, 2013
