rcosta
Jan 18, 2014Explorer
Thank you for the conversation.
I did not change anything, and it had worked correctly, so I don't think changing the wires in the switch would be the ultimate answer.
I did notice a blown fuse for the slide out, but I replaced it.
I was thinking reverse polarity because I noticed once when I hooked up the battery incorrectly, the slide out switch operated reversed as well. But today, when I switched the cable, nothing happened, including the lights.
With no shore power, the lights work, but the slide out switch is still reversed.
Tomorrow, I will look at some of the suggestions above.
Thank you again.
Thank you again.
44,066 PostsLatest Activity: Oct 04, 2013
