Hi - I'm looking for suggestions on things to try to fix my slideout before driving it 2 hours to a dealer. When i winterized last fall, everything was fine. When i tried to put my slide out this spri...
My slide does not work without the battery installed. Despite knowing that, I try to use the slide every spring with only the 110 power cord plugged in.
I read a recent post stating that the slide should work on shore power, I would just need to connect together the two wires that connect to the positive terminal on my battery. So simple, not sure why I messed that. Good to know (forget) for next Spring.
