mikemc53 wrote:
What would be the best location for stabilizers (Stack jacks probably) under any of the slides? It is hard to tell what is the frame and what is not. How about the actual slide arm? I would think as long as you support it on a flat and nowhere near any of the drive teeth it should be OK.
Thoughts?
Thoughts............
Contact the MFG. of your RV and ASK them about using slide out supports
Just because a product is offered/available via the aftermarket doesn't mean it is required, needed, is an improvement or that it is worth buying. Just means that it is 'for sale'---period.
Wonder why MFG. didn't include them with the RV :H
