Not sure what our measurements are on our topper, however.....if you get a good downpour it absolutely can and will pool on the awning. Simple fix.....slowly put the slide - we use the start/stop/start/stop method - in allowing the water to run off, then put it back out. We usually will do this a couple of times just to make sure the water did drain off. The awning fabric will have some give to it, just as your large awning does, so just make it part of your routine to put it in and out a couple of times and you'll be fine.
