ScottG wrote:
Mine has a plastic or nylon threshold it slides over. From stepping on it while the slide was partially in, we broke it. I ended up designing rollers to replace it.
Also, my buddy was warned not to step on the slide floor of his new Arctic Fox.
So apparently there are some designs where the slide floor should be avoided when it's not all the way out.
I may have to get a look under there and see what we have for supports.
Heck, I'd used dense foam wedges when the slide is closed to support it before we'd decide to NEVER use the slides when stopped for a quick lunch.
Don't know if that is practical or even possible yet. From what I understand it is the risk of separating an unsupported floor from the side's walls that is the risk. Hmmm.....
