hawkeye-08
May 26, 2016Nomad
We level first (with slide side slightly higher), then deploy slide, then put stabilizers down. If I put stabilizers down before slide goes out, then the slide side seem too tight and the other loose. That is just how I do it, I don't overthink it.... I have no problems either way really. I also check chocks and stabilizers after an hour or two. Tires cooling and soft ground can loosen things up...
