plasticmaster's avatar
May 26, 2016
slides first or stabilizer jacks first?
On a travel trailer with 2 large slides on one side, is it better to run the slides out first, or deploy the stabilizer jacks first? Thanks.
  • I too wondered this. Months ago I asked Northwood and they said setup in any order you wish. Same with using slide - In, out, sittin, or chillin, don't matter. Sometimes I put slide out then stabilize if the wife want to go in and do stuff otherwise I will stabilize and then put out slide. I've seen zero difference either way.
  • ford truck guy wrote:
    Level and stabilize first... Then deploy the slides
    Just what our manual says we should do....
  • Level. Stabilize. Extend Slides. Re-tighten jacks on non-slide side if needed.
    No need in my view to worry about too much weight on the jacks. The jacks will hold (in my case) about 6k lbs each. My trailer weighs 9k max.
  • I level, stabilize then extend the slide, so I don't have to crawl under the slide to stabilize.
  • One of our stabilizer jacks is under the slide. So unless I want to crawl under the slide to lower the jack...
