AnEv942
Feb 12, 2018Nomad
Grit dog wrote:
That seems strange. Means every time you stop for lunch or a quick sleep you have to run the legs down to the ground to run the slide out?
Well no, our camper is fully usable with the slide in, don't deploy for lunch/quick stops. Been a few overnighters where I only dropped jacks on slide side to run it out. Have never deployed slide with jacks up.
As jimh425 alluded to ours is also a 2001- slide mech not so much the issue, the large full wall square hole is. Structure isn't what might be found in newer units. Also easily racked.
I wouldn't hesitate to deploy our slide on flat slope but my point, as I gather OP new to T/Cs and possibly an older unit, was only a caution on using slide regardless of slope. If OP has manual and it states putting jacks down I would heed.
44,056 PostsLatest Activity: May 04, 2014
