twxsby89
Jul 24, 2016Explorer
Sloppy Tranny
Just curios to know if others that tow a lot, notice when you are backing up to hook up, and you get that ball perfectly lined up under the hitch, and you put it in park, the truck rolls forward sever...
Terryallan wrote:
Don't believe the movement is in the trany. I'm pretty sure it is in the U joint, and diff. After all. Once you put it in park. The trany is disengaged, and the rear end is holding the vehicle.
IF you would ever raise both rear tire off the ground with the selector in Park. You could see that IF you turn one wheel forward the other will spin backwards. It is designed so that when in park. they fight each other and keep the vehicle from rolling.
