hhornig's avatar
hhornig
Small Adjustable Propane Heater
My dog and I travel across the country in my pickup during the colder months and we sleep in the shell in back. Sometimes a little heat would help. I have used a Mr. Heater and it roasted me out in the lowest setting.
Does anyone know of a safe small heater that would meet my needs?
  • hhornig wrote:
    Jayco-noslide wrote:
    The Vornado is tops for even heat but pricey at around $100. I use it at home and in the motorhome and don't need the motorhome furnace until it gets down in the 40's or lower.
    Do you know if it is adjustable?
    Vornado operates on 120 VAC.
    I believe you are after a propane heater.
    The Coleman Black Cat has High/Low & at 3,000 BTU may still be too much in such a small space. But it may be the smallest you can find.
  • Gripnriprod wrote:
    You might try a Coleman Black Cat. Had one when we tent camped.
  • The Vornado is tops for even heat but pricey at around $100. I use it at home and in the motorhome and don't need the motorhome furnace until it gets down in the 40's or lower.
