kincade wrote:
The length of the 2185 is about max for us so most of the trailers mentioned here won't work for us. The Jayco X231 would work as it's about 2' shorter so we plan to look at one of those as well.
Thanks for all the feedback.
Since the 2185 is 26' in length, it's much longer than your Roo. Surprised that length would work for you.
I will admit that the 2185 is a nice floorplan, if not a bit small and cramped for a family of 4. You should be able to find this floorplan from other makers as well. I wouldn't be surprised if Forest River had it as well.
I think you'll like the Jayco. It's a VERY NICE camper. The problem with a bed slide out is that it can get cold in late fall months from the lack of air space in-between the floor and the mattress. However it's a very large bed, second to none, and a mat heater can most likely take care of that cold. It has a much better living area with 2 large bunks, a separate sofa sleeper, a standard sized dinette/ sleeper, and a large permanent 'king' bed. The only downfall is it's laminated build quality to save weight along with it's lower ceiling height of 78" .
