Farmerjon
Jul 29, 2014Explorer
I was voting for the static problem as we have cloth seats in our truck and when humidity is just right we get a spark.I'm tempted to drag a ground wire along the road under the truck.
Wow you just thru a wrench into the works.
you have a deadly situation going on. you need to check all of your 120 connections and check your inverter connections making sure it is well grounded to the skin and the frame.amd not use it until you find the problem . If you can't find a wiring problem contact the manufacturer for help.
good luck.
good luck.
