kfp673
Aug 29, 2020Explorer II
Lynnmor wrote:
If I read this right, the tongue weight is way too low and sway is a real possibility. That 900lb tells me that it has toys for tires and it will not carry enough. Skip it.
After further research, the dealers website does not match Jayco. Imagine that ;-) jayco website has it listed as dry weight 4700lb, 6k GVWR and 465lb dry hitch. The truck payload is 1155. Online Toyota shows a tongue load rating of 640lb max tow 6400lb.
I know all about dry ratings so after doing some simple estimates, it seems like this trailer is basically right at the max. Obviously payload is the big variable depending on what they load the truck/trailer with, but in general it seems right at the max. Do you all agree? Too much for that truck? Think it will be ok?
