Grit_dog
Jun 25, 2021Trailblazer
MarkTwain wrote:Baja Man wrote:
So we made compromises....smaller TT, lighter weight,
Buy an additional holding tank that you strap to back of your RV.
Bad idea...
But you know, it helps when the OP is present and active in the conversation. In another thread he said he was planning on carrying water jugs.
Below is an example of what I was suggesting, although you can get a similar setup for less than half this much $. This is an expensive setup.
It is literally the easy button for hauling water, and comparable in $ if you're wanting to bring more than a few jugs. You have almost unlimited length (within reason) with the pump electrical hookup and add whatever length hose you need. Fill it up in the back of the truck at home or wherever, plug it in and fill camper when needed. Anywhere from about 250lb to 1100lb depending on how much water you want.
I used to put a 450lb bag on the floor of the back seat in the truck. Been using the same bag(s) in our boat for surfing and for hauling extra camper water for many years now, when needed.
https://www.wakemakers.com/straight-line-sumo-max-850-bag-pump-combo.html
44,072 PostsLatest Activity: Aug 23, 2026
