Huntindog
Jun 30, 2014Explorer
the bear II wrote:If you can dig a hole in a concrete pad with a shovel.... You are a better man than I.:B
"I dig a hole for the high side. A shovel is a mighty handy tool to have with you."
I think the RV park we are in would be pretty upset if I dug up the concrete pad which is about 2 inches unlevel, so I use blocks to level the 5th wheel.
As for the pad being that far out of level... Pretty poor workmanship, don't you think?
I wonder about the electrical wiring and water supply at such a place. If what you CAN see is bad, you can bet the hidden stuff is worse.
How much are they charging for such fine facilities?:E
44,056 PostsLatest Activity: Jan 12, 2020
