Sort By
- DiskDoctrExplorer
Huntindog wrote:
The rain situation happened to me. I have seen it happen without any moisture to help. I was at a trial one time. Having lunch and looked out the window to see a commotion going on at another TT. Lots of activity and a crowd around it. I went over to see what was up. The DRY soft dirt had given away, causing the TT to fall off of the blocks. His wheel chocks had also given away. The tongue jack and stabilizers had folded up, and the TT tongue was sitting in the dirt. They were now digging a hole under the frame trying to get a hydraulic jack in there..... What a mess.
There was already plenty of help there. So I just told the owner to come see me when he was done, and I would show him what I do to prevent this from happening again.... He is now a no block convert. I catch a lot of flak on this forum about this procedure.
But it flat out works. It is simple, and you can forget about what is the best blocks.
I never said that one can dig thru concrete.... That SHOULD already be level... If it was done right. And of course in a campground (What is that) There are many rules that one MUST follow... Digging holes is probably just one of them.
But the poster, I was responding to, seemed to be a boondocker, at least some of the time... This option would probably be available to him.
We use long boards under both low side tires of our HTT. Never needed more than 3. The tongue, however, has been maxed high and low without any problems.
The key is to use wheel chocks on both front and back of tires. There shouldn't be ANY stress on tongue jack other than up and down. - Nvr2loudExplorer II
Huntindog wrote:
n7bsn wrote:
Priceless == lynx levelers. Anyone that thinks they are worthless either has power levelers or only camps at flat, paved, "RV" resorts.
Every summer we have at least one trip where we park in a field. Without one type of leveler or other, we would be camping at a considerable slope.
I NEVER use blocks of any type. You haven't lived until your TT has fallen off of the blocks due to the ground giving away in a rainstorm. Then the TT wants to roll.
I dig a hole for the high side. A shovel is a mighty handy tool to have with you. You can throw dirt on a fire, scoop up dog crap, and level your TT by digging a hole. Make gravity work for you. A TT can't fall out of a hole.
+1
I use the shovel method in most sites too. - dave17352Explorerdouble post
- dave17352Explorer
Huntindog wrote:
I agree with the lynx leveling blocks being awesome, they just work much nicer than wood blocks. Yes they're more $ than wood, but they're not that expensive either.
Huntindog, that's a great idea for a shovel to have handy. I keep that and an axe at all times. For most people who don't boondock though, a campground would get pretty mad if you're digging holes on their sites. Also many campgrounds are paved spots, no digging there.
Huntingdog:
Perhaps where you are at this is a typical problem. I can't imagine digging holes to level on a regular basis. Also when using the truck camper when going shopping or stopping on a trail or any brief stay I just look at my bubbles and in a moment or two my truck is level for the fridge with lynx levelers. You just can't beat them! JMHO - HuntindogExplorer
But the poster, I was responding to, seemed to be a boondocker, at least some of the time... This option would probably be available to him. - niksagkramExplorerCan't believe my must haves haven't been mentioned yet.... bungee cords (i have lots) duct tape, and a good tarp! Indispensable!!
- dave54NomadMust -- good pair of binoculars.
How else can you determine if the movement in the far off tree is a Cassin's Finch or Purple Finch? It takes a sharp eye to see the slight variation in color pattern on the head to identify which. ;)
A magnifying hand lens, to look at the small colorful bugs and flowers. A set of bird, flower, plant, etc guidebooks.
I use to diss the lynx levelers too, until I obtained several sets. Now I no longer use wooden blocks.
Useless -- a portable fire ring. Haven't had a campfire in years. Don't need 'em, don't miss 'em. I look at stars at night, or take a walk in the moonlight to see what wildlife is out and about. - myredracerExplorer IISnake oil - TP that is labelled for RV holding tanks but does not break down/disintegrate. Some RV brands do and some don't. They charge mafia prices just 'cuz it says "RV" on it. A few household brands disintegrate just fine like the Costco one we use and are way cheaper.
Must haves - Sodastream pop maker along with the diet flavors. Corel microwave safe dishes. La Jolla plush recliner. Verizon 4G service and computer. Wineguard Wingman. - sbowman871ExplorerMust have: A partner that loves camping as much as you do.
- 69_AvionExplorer
downtheroad wrote:
Must have: (the 2 senses)- Sense of humor
- Common sense.
Best advice yet.
44,028 PostsLatest Activity: Apr 15, 2025
