rbpru's avatar
rbpru
Explorer II
Feb 11, 2018
Snow load.
Does anyone have information on the weight of snow. We had the typical four to six inches of snow then thaw then repeat. However, this last snow came fast an continuous.
Looking out the window it was obvious there was more than a few inches of snow on the TT. So with ladder and push board I headed out.
Well there was 10 inches of packed not fluffy snow. Heavy and hard to push. I have a "Lite" TT with a no walking on roof.
So the question is, what is the weight of a square foot of 10 inches of snow?
  • Ten inches in a lot of packed snow.
    Residential roofs generally don’t like more than 20lb per square foot.
    Packed or saturated snow weighs about 20lbs per sq. ft.
    You can do your own math to determine if you think approaching the load limit for a residential roof is OK on a trailer or not.
  • To add a little levity to this thread, the answer to your dilemma is: "southern Arizona".
    It is currently 75 degrees and sunny here just west of Tucson.
  • From shoveling snow, I can tell you the weight of snow goes from:
    this is annoying
    this sucks
    this really sucks
    wish I wouldn't have sold the snow thrower
    I wouldn't worry too much about 10 inches of snow even though you have a no walk roof. Your trailer was designed by people who live near you.
  • I hope it's not a problem because I probably have a foot of snow on my tarp covered TT and I'm too lazy to go out there and try to get some of it off.
  • wnjj's avatar
    wnjj
    Explorer II
    ktmrfs wrote:
    One common "rule of thumb" is that 10 inches of snow is around 1 inch of water. However I'd say from experience that number can likely vary from 3:1 to 20:1 depending on how dense the snow is.
    And inch deep water over a square foot weighs about 5 lbs spread over 144 square inches, not even in the same universe as the pressure a person can apply walking or worse yet kneeling.
    depends. unlike water or other solids, snow is not a defined weight per unit volume. It's going to depend a great deal on the temperatures when the snow falls as how dense it is.
  • Depends. Wet snow can weigh more than dry snow. If you really want to know gather 1 cubic foot of snow, melt it and weigh the water.
