Roman_Duck
Apr 16, 2014Explorer
sarahbyu1 wrote:
You're all so fabulous. Thank you!
It does NOT have the HD towing package.
It has a receiver that says the GTW is up to 5000 lbs.
Is that the end of the story? 5000 pounds?
No that is not correct.
Its simple
On your drivers door post there should be a sticker
The sticker will have tire size, air pressure and weight info.
Under the weight info it will give a couple of sets of numbers;letters
The two your interested in are:
1/ gross vehicle weight(GVWR). meaning the actual manufactures weight of vehicle.
2/ Gross combination weight)GVCWR), meaning the vehicle weight loaded with persons, fuel, and any towed vehicles
Now for alittle math:
Subract the GCVWR //your camper weight from
Your GVGW (also found on the title,and registration)
Example
TV weight without persons, fuel or traile (GVWR) 3850 lbs.
TV Maxiunm allowed weight (with trailer) (GCVWR) 6750 lbs.*
What your max weight capability is 2900 lbs.**
* Includes people, belongings, fuel, your camper fully loaded, including propane water, and all the rest.
above is an example only, not knowing your TV or what your looking to pull. Each vehicle depending on the manufactures options will have varying abilities.
** The amount of weight that you can add to the TV and drive it safely without overloading.
Another method is to contact the TV dealer and give them the vin number and they will be able to also tell you.
Hope its helps with understanding the DOT rating mandated on most late model door post
44,068 PostsLatest Activity: Jun 10, 2026
