azwildcat99
Aug 28, 2014Explorer
oceanluver wrote:
In NY anything over 5500lbs needs commercial plates, or you need to have a cap on it, with seat buckles in the back and permanent camping gear. Ridiculous. Some dealers said they can grease someone's palm to get you a cap receipt and register it with passenger plates and other dealers said no you need to be commercial. Very annoying.
Wow! I just read the NY DMV regs and I can't believe that is true. Essentially every 1/2 ton and above crew cab pick-up in NY is a commercial vehicle unless it has a camper shell as they all weigh more than 5500lbs gvw. Crazy!
Regardless you can get a camper shell and be okay even with a 3/4ton as the truck must have seats, not the bed. Notice the "or" clause.
Glad I live out here in the Wild West :B
NY DMV
Pick-up Trucks (Part 106.6 (c)) - you can register a pick-up truck in the passenger class if the pick-up truck complies with all of these requirements
* the pick-up truck has an unladen weight of more than 5,000 lbs. and is used for non-commercial purposes
* the pick-up truck does not have any business advertisements
* a permanent camper top completely encloses the truck bed, and which has one or more side windows
* the pick-up truck has seats, seat fittings, or permanent camping equipment installed in the truck bed
44,068 PostsLatest Activity: Jun 10, 2026
