scool191
May 12, 2014Explorer
So Confused
I am so confused by all of this. I am looking to buy a new travel trailer. I drive a 2011 Ford F150 Supercrew V6 3.73. Per Ford the max tow weight is 5700 pounds. The trailers I'm looking ...
Bumpyroad wrote:donn0128 wrote:
So lacking anything else use the GVWR number. Using max permissable numbers will always ensure that you are erroring on the side of caution, and not throwing caution to the wind.
so you can blindly follow the GVWR number and as long as that is below permitted tow weight you are OK? even if you have no idea what your rig weighs?
I don't think so.
bumpy
